NX VB Journal - Create CenterPoint of an Arc
Okay, I'm just trying to get NX to put a point at the center of an arc.  Seems simple enough in concept.  But it's not working for me.  Here's my code (ultimately I'm just trying to get the "createpoint" method to work - the rest is just to try it out):
CODE
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports System.Windows.Forms
Imports System.Environment
Module report_selected_object_type_and_subtype
    Sub Main
         Dim s As Session = Session.GetSession()
        Dim ufs As NXOpen.UF.UFSession = NXOpen.UF.UFSession.GetUFSession()
        Dim selobj As NXObject
        Dim arc1 as ibasecurve
        dim workpart as part = s.Parts.Work
        dim cpoint as point = nothing
        dim kk as integer=0
        Dim type As Integer
        Dim subtype As Integer
        Dim lw As ListingWindow = s.ListingWindow
        While select_anything(selobj) = Selection.Response.Ok
            ufs.Obj.AskTypeAndSubtype(selobj.Tag, type, subtype)
            lw.open()
            lw.writeline(selobj.tostring)
        End While
        arc1=ctype(selobj,ibasecurve)
        cpoint=workpart.points.createpoint(arc1,smartobject.updateoption.withinmodeling)
        cpoint.SetVisibility(SmartObject.VisibilityOption.Visible)
        End Sub
    Function select_anything(ByRef selobj As NXObject) As Selection.Response
        Dim theUI As UI = ui.GetUI
        Dim cursor As Point3d
        Dim typeArray() As Selection.SelectionType = _
            { Selection.SelectionType.curves }
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObject("Select anything", _
                Selection.SelectionScope.WorkPart, _
                false, typeArray, selobj, cursor)
        If resp = Selection.Response.ObjectSelected Or _
                resp = Selection.Response.ObjectSelectedByName Then
            return Selection.Response.Ok
        Else
            return Selection.Response.Cancel
        End If
    End Function
End Module
If I have an arc on the screen I click on it and the journal completes without errors but I don't get any new points created.  Is there another method I should be using?
Jeff
RE: NX VB Journal - Create CenterPoint of an Arc
Oops, nevermind - I moved the first EndWhile after the SetVisibility and it worked!
I knew I shoulda waited until I gave it one more kick at the can!
If you are creating multiple points, move the point creation code into the while loop.
CODE
 'ufs.Obj.AskTypeAndSubtype(selobj.Tag, type, subtype)
 'lw.writeline(selobj.tostring)
              'remove parameters to create dumb point, keep them to create smart point (will follow the arc, but is not a point feature)
              'cpoint.RemoveParameters()
        End While
If you are only creating 1 point, change the while loop into an if block.
CODE
        If select_anything(selobj) = Selection.Response.Ok
        End If
www.nxjournaling.com
Also bear in mind that your code as is will create a "smart" point object; if the arc is moved it will follow, but it is not a point feature. I know of no way to create such a point in interactive NX, it may confuse other users of your file. If you want to create a "dumb" point, remove the parameters after the point is created (line is commented out in my code above). Alternatively, it would only take a few more lines of code to turn it into an associative point feature (the type that shows up in the part navigator).
Here's an example for the point feature:
CODE
        if select_anything(selobj) = Selection.Response.Ok
              '*** start of code to create point feature
            Dim nullFeatures_Feature As Features.Feature = Nothing
            Dim pointFeatureBuilder1 As Features.PointFeatureBuilder
            pointFeatureBuilder1 = workPart.BaseFeatures.CreatePointFeatureBuilder(nullFeatures_Feature)
            pointFeatureBuilder1.Point = cpoint
              'nXObject1 will be a reference to your new point feature
            Dim nXObject1 As NXObject
            nXObject1 = pointFeatureBuilder1.Commit()
            pointFeatureBuilder1.Destroy()
              '*** end of code to create point feature
        End if
