Flow Bench Instrumentation
Our company is working with a Spartan budget and I have been asked to develop INEXPENSIVE flow measurement for air flow into our product. We have air actuated tools that we want to check the air flow consumption of in order to provide a guide to our customers of the minimum air requirements to operate our equipment. This is necessary because our tool is often used in remote areas with limited air options so we want to give our customer guidelines on what they need to provide for full tool capability and how much to der-rate the tool's capability for lower than optimal air supply.
The least expensive route appears to be to measure the Differential pressure over a 15 foot stretch of straight pipe while the tool is in operation. Using the formula on this site, it appears that around 55 cfm and 90 psi (Our expected compressor pressure for our flow bench) we would have around 20 inches of pressure drop across this 15 foot section of straight pipe. Lower flows will obviously result in a lower differential pressure reading and of course higher ones would show a higher pressure drop as well. The idea is to just use a long section of straight pipe instead of using an orifice plate.
My question is whether this method will provide a reliable flow reading. If so, we will get a Differential Pressure transmitter with display readout and use the formula to determine our flow based on the Differential pressure readout. We don't require super accuracy but we do hope to have reasonable accuracy (Say within 5%). If not, is there a better means that isn't cost prohibitive ? Thanks for the help. Our pipe size is 3/4".
RE: Flow Bench Instrumentation
Your accuracy will be limited to either: 1) the accuracy of the assumptions you will make in characterizing your length of pipe, or 2) the accuracy with which you calibrate your transmitter (flow computer). Or both.
Your method will be very repeatable. The challenge is getting an accurate flow at a single point so you can calibrate it. If you know true flow at one measured pressure drop, you should be good to go as long as your density (temperature, moisture content) doesn't change much. If you're concerned about true accuracy, see if you can calibrate it closely somehow. Rent or borrow an accurate flow meter? Blow air into a calibrated balloon or container?
That's my take.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Turn off the compressor. Run the the tool for say 15-30 seconds. Check the new tank pressure - do the math!!
Not all that accurate - but very CHEAP and might be good enough??
Roy
