Code Case 2235-9
Code Case 2235-9
Is the CC2235-9 the last revision of this code case?
I am constructing a equipament acordding to ASME VIII div I ed 2010. I have been told that CC2235 has been incorporated to Asme 2010, but I only found it in Asme VIII div 2.
Should I use then the code case 2235 or consider Asme VIII divII?
RE: Code Case 2235-9
