CONN3D2 element only in tension
Is there a way to have a CONN3D2 element that only works in tension ?
RE: CONN3D2 element only in tension
Can you precise your question.
You want to have no element stiffness during compresion or during unloading phase of tension?
Bartosz
Hi akabarten,
 I want to have no element stiffness during compression. Only during traction.
 Thank you. Regards,
Martin
Nonlinear elastic deinition is not enough for you?
*CONNECTOR BEHAVIOR
*CONNECTOR ELASTICITY, NONLINEAR
**  force, disp
 -1.0e-06, -1.0
      0.0,  0.0
      1.0,  1.0
     10.0,  2.0
As you can see compression resistance is set to very small value.
Bartosz
Hi akabarten.
 Awesome, thanks. I'll try that.
Martin
