Depicting PLC control on Process Flow Diagrams
Is there a good way to show PLC control logic, both analog and discrete, on a PFD?  How would one show manually-inputted PLC parameters (e.g., a manually-inputted flow limit)?
RE: Depicting PLC control on Process Flow Diagrams
You cannot squeeze it all onto a PFD, create separate diagrams and put a cross reference to them on the PFD.
Or use ControlDraw and add the PLC logic as linked diagrams.
Francis
www.controldraw.co.uk
www.s88control.blogspot.com
PLC/DCS Logic is not typically shown on a PFD. The PFD is used more for presenting flows, temperatures, volumes, pressures of the process at a higher level.
The P&IDs are what should contain the PLC/DCS logic. Take a look at ISA 5.1 for reference on how to show the PLC logic.
______________________________________________________________________________
This is normally the space where people post something insightful.
You cannot squeeze it all onto a P&ID either, create separate diagrams and put a cross reference to them on the P&ID.
Francis
