AutoCAD Ribbon and Grip selection of objects
A Portion of my AutoCAD Ribbon disppears when using grips picking objects. I say a portion of ribbon is the far right side disppears to the middle and a another ribbon appears with multi-objects. Why? aned what to do to eliminate this multi-object ribbon to not attach.
RE: AutoCAD Ribbon and Grip selection of objects
Actually, this is more of an Adobe Reader / Acrobat question than an AutoCAD question.
When I plot AutoCAD dwgs (AutoCAD LT 2012), I use 22x34 paper size and use Autodesk's virtual printer DWG to PDF.pc3.
This creates a clean pdf with layer control.
However, when I print "half size" dwg to my 11x17 printer, Adobe Reader scales to 48% instead of 50%. This defeats the whole purpose of the ANSI sheet size scheme.
Can I persuade Abode Reader to print true half size (exactly 50%)?
I'm fairly sure this is not an AutoCAD issue, as it seems to be doing its job well.
I prefer to not have one half size pdf set and one full size set for record dwgs.
A quick fix available, or just use a different pdf viewer with scaling properties for printing?
