Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
Bert2 (Mechanical)
19 Mar 12 11:58
I have a question regarding cast in situ bridge girders relative to a load imposed considering pre-tensioning and ultimate elongation of strands.
Specific details;
Length of span = 30M
Grade of Strands = 270k / 0.6"
Pre tension imposed = 19500kg / Strand
Neglect compression effects of concrete girder.
Load = UDL of 270Te (270000Kg)
Neglect any Dynamic inputs – only consider as a static load.
I'am aware of AASHTO std however using Hooke's law principles is there a way to calculate Sigma / Epsilon / x elongation; given the pre-load applied..? guess it won't be as simple as to '-' the pre-load off the imposed load...
Thanks for any replies! – I know it's a bit different.
Cockroach (Mechanical)
20 Mar 12 9:05
I guess you could do a deflection based on load and obtain the equation of that curvature. Then the elongation would be the arc length of that geometry less the length of the undeflected member. This is the classical approach to beam design taught in static courses with a little bit of calculus.
Cockroach
GregLocock (Automotive)
20 Mar 12 23:11
Simple answer, yes obviously, build an equivalent beam. Ignoring compression in the concrete makes it rather futile though.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Close Box
Join Eng-Tips® Today!
Join Us             Close
