Hole series options
Hole series options
Hole series options
why there isn't threaded hole on start hole type ?
At the moment I need to promote components and add the same threaded hole type for each components.
Correct solution or there is something better ?
Thank you...
Using NX 8 and TC8.3
RE: Hole series options
I'm a bit hard-pressed to visualize a situation where one would NEED that the 'Start' hole be Threaded.
Can you provide an example where this is needed and where it couldn't be accomplished by starting the 'Hole-Series' from the opposite side thus making the 'Threaded' section the 'End' hole?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
That picture is meaningless.  Why couldn't the 'Hole-Series' be started from the other side?
John R. Baker, P.E.
Industry Sector
Cypress, CA
