italian tolerance standard on drawings
hello - i have a set of drawings from italy that in the drawing title block it refers to the tolerance as a check box w/ min - med - max. then refers to a standard as general processing tolerance uni 5307-63 - could someone please dorect me to this spec or any info pertaining to this - any help would be greatly appreciated - thank you in advance
RE: italian tolerance standard on drawings
Frank
Interestingly, the website for UNI - the Italian standard body - returns zero search results for UNI 5307-63, as if it was discontinued several years ago.
Frank
http:/
has the tolerances tabulated(check out the title block) and they don't look much different from ANSI or ISO counterparts.
Sorry duk748.
possibly...
grado MEDIO = middle grade
"Tolleranze generali: a norma UNI 5307/63 - grado MEDIO - fori tolleranza+/alberi tolleranza-Øesterno "
Coarse is on top.
Checkers...
