Problem on draft
Problem on draft
I'm not able to draft a part.
In the example attached without the boss I'm able to draft, but with a boss I'm not able to draft.
Can someone help me to understand if there are some draft otpions to set or something different ?
Thank you...
Using NX 8 and TC8.3
RE: Problem on draft
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
the are two situation where I ask for a solution :
1) On imported file
2) Usually I put draft and bends at the end of my project
If therer aren't draft options solutions, how resolve on this two situations ?
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
