Joint Design "V" or Fillet
I am seeking a help in the subject matter. I am working on a project where Steel structure is in our scope. We have a Turbine building where we have a Main column having Web Thickness of 25-50 MM and Flange 40-63 MM.
My query is " Can we go ahead with Fillet weld between Web and flange joint. ?" request you to kindly suggest refrence documents for the same.
Aakash
Aakash
RE: Joint Design "V" or Fillet
http://www.FerrellEngineering.com
It bothers me that you ask the question, It implies that you are not sufficiently knowledgeable in this field to be doing this work without the supervision of a qualified mentor. Your structure needs a well qualified and experienced structural engineer, it is not work for beginners.
Michael.
Timing has a lot to do with the outcome of a rain dance.
Check what your local code says.
I would think that single pass fillet welds would be insufficient.
