Joint Design "V" or Fillet
I am seeking a help in the subject matter. I am working on a project where Steel structure is in our scope. We have a Turbine building where we have a Main column having Web Thickness of 25-50 MM and Flange 40-63 MM.
My query is " Can we go ahead with Fillet weld between Web and flange joint. ?" request you to kindly suggest refrence documents for the same.
Aakash
RE: Joint Design "V" or Fillet
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
But, if the forces allow a combination of groove welds, fillet welds, and/or stitch welds may be more economical.
http://www.FerrellEngineering.com
