Load Factors for Design of a Trailer Frame
Does anyone have an idea about what would be a suitable vertical load factor for the design of a trailer?
Thanks in advance
Thanks in advance
RE: Load Factors for Design of a Trailer Frame
http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/vsb_06_h.pdf
I had not read it, but it looks like it could helpful
The load distribution was easy to calculate.
This load factor resulted in elastic deformation only.
I was just curious if there were any published standards regarding load factors for trailers....
Cheers
was that 10g vertical load factor a gues or did you base that on something?
It is just a guess based on the aviation forward crash load factor of 9g + 1 for luck.
Is this trailer for aircraft use?
If it is beware of flexing loads at the towbar/ gooseneck attach points.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
