NX VB Journal - Creating Spline using PtSlopeCrvatr Container
This is related to the askfacedata/askfaceprops code I am working on but it is a separate question - so I figured I post it on its own.
I am trying to create a spline ultimately using CreateSplineThruPts but first I need to populate the PtSlopeCrvatr with data. I have declared my variable as:
But I still get "Object reference is not set to instance of object" as soon as I try to assign as follows:
How do I initialize the variable properly to be able to put data into it?
Jeff
CODE
dim PTDATA() as NXOpen.UF.UFCurve.PtSlopeCrvatr = New NXOpen.UF.UFCurve.PtSlopeCrvatr() {}
CODE
for p as integer = 0 to totalpoints
PTDATA(p).point(0)=ptx
...etc...
...etc...
Jeff
RE: NX VB Journal - Creating Spline using PtSlopeCrvatr Container
CODE
Dim total As Integer
total = 3
ptx(0) = 0
ptx(1) = 1
ptx(2) = 2
Dim PTDATA() as NXOpen.UF.UFCurve.PtSlopeCrvatr
ReDim PTDATA(total)
For p As Integer = 0 to total
PTDATA(p).point = ptx
Next
www.nxjournaling.com
Jeff
Which line of your code reports an error, and what does that line look like?
Also, note the difference above
CODE
(0)=ptxwww.nxjournaling.com
Jeff
CODE
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim ufs As UF.UFSession = UF.UFSession.GetUFSession()
dim myTag as Tag 'tag for the new spline to be created
dim mySpline as Spline = nothing 'object variable for new spline
dim degree as integer = 3 'degree of spline created
dim periodicity as integer = 0 '0 for non-periodic, 1 for periodic (closed) spline
dim numPoints as integer = 4 'number of points passed to the CreateSplineThruPts method
'declare and populate point data
dim pt0(2) as double
dim pt1(2) as double
dim pt2(2) as double
dim pt3(2) as double
pt0(0) = 0
pt0(1) = 2
pt0(2) = 0
pt1(0) = 2
pt1(1) = 1
pt1(2) = 0
pt2(0) = 4
pt2(1) = 3
pt2(2) = 0
pt3(0) = 6
pt3(1) = 0
pt3(2) = 0
dim ptdata() as NXOpen.UF.UFCurve.PtSlopeCrvatr
redim ptdata(3)
ptdata(0).point = pt0
ptdata(0).slope_type = UF.UFConstants.UF_CURVE_SLOPE_AUTO
ptdata(0).crvatr_type = UF.UFConstants.UF_CURVE_CRVATR_NONE
ptdata(1).point = pt1
ptdata(1).slope_type = UF.UFConstants.UF_CURVE_SLOPE_NONE
ptdata(1).crvatr_type = UF.UFConstants.UF_CURVE_CRVATR_NONE
ptdata(2).point = pt2
ptdata(2).slope_type = UF.UFConstants.UF_CURVE_SLOPE_NONE
ptdata(2).crvatr_type = UF.UFConstants.UF_CURVE_CRVATR_NONE
ptdata(3).point = pt3
ptdata(3).slope_type = UF.UFConstants.UF_CURVE_SLOPE_AUTO
ptdata(3).crvatr_type = UF.UFConstants.UF_CURVE_CRVATR_NONE
'ufs.Curve.CreateSplineThruPts(degree, periodicity, numPoints, ptdata, _
' user specified parameterization of input points: use 'nothing' for default parameterization, _
' save defining data? 1 = yes (anything else = no) , return tag variable of new spline)
ufs.Curve.CreateSplineThruPts(degree, periodicity, numPoints, ptdata, nothing, 0, myTag)
'convert Tag reference to NXOpen object
mySpline = Utilities.NXObjectManager.Get(myTag)
'prove that the above line worked
msgbox("Length of spline: " & mySpline.GetLength)
End Sub
End Module
Now I understand the spline construction. Still working on the overall picture. More posts to come ;)
Jeff
The problem is I am assigning the .point data in a For-Next Loop and it reports everything ok, but as soon as I exit the loop it only remembers the last value.
CODE
pointdouble(0)=cpoint(p).coordinates.X
pointdouble(1)=cpoint(p).coordinates.Y
pointdouble(2)=cpoint(p).coordinates.Z
point_data1(p).point = pointdouble
point_data1(p).slope_type = UFConstants.UF_CURVE_SLOPE_NONE
point_data1(p).crvatr_type = UFConstants.UF_CURVE_CRVATR_NONE
lw.writeline("K= " & p.tostring &": " &point_data1(p).point(0) &","&point_data1(p).point(1) &","&point_data1(p).point(2))
next p
for p as integer = 0 to kk-1
next
Gives me:
K= 0: 80.0068723329663,0.000311697607848771,25.0000086444894
K= 1: 82.6184557205712,0.0890023374493865,25.0002787371683
K= 2: 85.3356535714023,0.362087419874367,24.9997263024703
K= 3: 88.0324414244833,0.840184094211939,25.0008079122174
K= 4: 90.6374012069239,1.52693367761155,25.0014357866076
K= 5: 93.0355329341884,2.41816831811692,24.9993864675541
K= 6: 95.1594576479436,3.48239559087328,24.9988022552044
K= 7: 96.9428619602756,4.68411422968257,25.0003322542663
K= 8: 98.3237291689222,5.98321234054376,24.9988888939346
K= 9: 99.2751578945642,7.33331493597748,25.0002114846827
K= 10: 99.8265572327264,8.68491999661199,24.9998931806953
K= 11: 100,10,25
K= 0: 100,10,25
K= 1: 100,10,25
K= 2: 100,10,25
K= 3: 100,10,25
K= 4: 100,10,25
K= 5: 100,10,25
K= 6: 100,10,25
K= 7: 100,10,25
K= 8: 100,10,25
K= 9: 100,10,25
K= 10: 100,10,25
K= 11: 100,10,25
So as soon as I exit the loop my point values are "lost". This is probably something VB related which I don't understand, and I guess I'm sorely lacking in VB training.
Thanks (again),
Jeff
Boil your code down to a small journal that exhibits the error and we'll step through the whole thing.
For what it's worth, here's my test code:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
' Explicit Activation
' This entry point is used to activate the application explicitly
Sub Main()
Dim lw As ListingWindow = theSession.ListingWindow
Dim myTag As Tag 'tag for the new spline to be created
Dim mySpline As Spline = Nothing 'object variable for new spline
Dim degree As Integer = 3 'degree of spline created
Dim periodicity As Integer = 0 '0 for non-periodic, 1 for periodic (closed) spline
Dim numPoints As Integer = 4 'number of points passed to the CreateSplineThruPts method
Dim pt0(2) As Double
Dim pt1(2) As Double
Dim pt2(2) As Double
Dim pt3(2) As Double
pt0(0) = 0
pt0(1) = 2
pt0(2) = 0
pt1(0) = 2
pt1(1) = 1
pt1(2) = 0
pt2(0) = 4
pt2(1) = 3
pt2(2) = 0
pt3(0) = 6
pt3(1) = 0
pt3(2) = 0
Dim ptdata() As NXOpen.UF.UFCurve.PtSlopeCrvatr
ReDim ptdata(3)
ufs.Curve.CreateSplineThruPts(degree, periodicity, numPoints, ptdata, Nothing, 0, myTag)
MsgBox("Length of spline: " & mySpline.GetLength)
lw.Open()
For i As Integer = 0 To 3
lw.WriteLine(ptdata(i).point(0))
lw.WriteLine(ptdata(i).point(1))
lw.WriteLine(ptdata(i).point(2))
lw.WriteLine("")
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
Can you post that line(s) of code?
CODE
...figure out value kk...
redim point_data1(kk-1)
I'll see if I can isolate a small working (or not) part of code that can be reproduced.
It's a question of assigning the .point values in the for-next loop.
Jeff
In the data that was written out I note that at k = 11 the data written out is the only data that is saved.
I think the wrapper method does not allocate space correctly.
I have two suggestions. One is to reduce the number of spline points and write out the data to test my theory. If this is proven then this wrapper method is of little use to you therefore my second suggestion is to use the spline class. If rquired I can make an example journal available.
Frank Swinkels
I modified my code to use loops similar to yours and saw the same problem. I think the problem is because objects (the ptdata object in our case) are reference types. This means they act like pointers; so when we loop through and change the data in pointdouble(), the object points to the new data rather than copying it into a separate variable.
One possible workaround would be to hold your point data in an array of arrays so that you have a separate copy of each point. This method is demonstrated below:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
Sub Main()
Dim rand1 As New Random
Dim myPoints()() As Double = New Double(numPoints - 1)() {}
lw.Open()
For i As Integer = 0 To numPoints - 1
myPoints(i) = New Double(2) {}
For j As Integer = 0 To 2
myPoints(i)(j) = rand1.Next(-10, 10)
lw.WriteLine(myPoints(i)(j))
Next
lw.WriteLine("")
Next
ReDim ptdata(numPoints - 1)
ptdata(i).point = myPoints(i)
ptdata(i).slope_type = UF.UFConstants.UF_CURVE_SLOPE_NONE
ptdata(i).crvatr_type = UF.UFConstants.UF_CURVE_CRVATR_NONE
lw.WriteLine(ptdata(i).point(0) & ", " & ptdata(i).point(1) & ", " & ptdata(i).point(2))
Next
End Sub
End Function
End Module
I don't bother to create the spline in this journal since the data is random. It might make for some interesting looking, but useless splines. The code above uses only 4 points, but I have tested with up to 50 points and all was well.
Jeff
