Hello!, With FEMAP & NX NASTRAN SOL 106 you have an easy way to perform modal analysis with pre-load. The key is to put the METHOD command in the case control and put an eigenvalue card, such as EIRGL, in the bulk data session. Also, param LGDISP needs to be specified to compute the differential stiffness, and NMLOOP should be a value not equal to zero so that the normal modes are computed based on the updated non-linear stiffness. Here is an example: $ $ Normal Mode Analysis with Preload - Solution 106 $ Note that LGDISP = 1 is set to get differential stiffness matrix $ case control METHOD = 10 calls eigenvalue module $ SOL 106 $ CEND $ TITLE = Normal Modes with Preload SUBCASE 1 NLPARM = 1 LOAD = 1 METHOD = 10 SPC = 100 DISPLACEMENT = ALL $ BEGIN BULK $ $------8-------8-------8-------8-------8-------8-------8-------8-------8------- 8 $ $ Param Cards $ PARAM WTMASS 0.00259 PARAM COUPMASS 1 PARAM POST -2 $ $ Nodes $ GRID 1 0 0. 0. 0. GRID 2 0 10. 0. 0. GRID 3 0 20. 0. 0. GRID 4 0 30. 0. 0. GRID 5 0 40. 0. 0. GRID 6 0 50. 0. 0. GRID 7 0 60. 0. 0. GRID 8 0 70. 0. 0. GRID 9 0 80. 0. 0. GRID 10 0 90. 0. 0. GRID 11 0 100. 0. 0. $ $ Bar Elements $ CBAR 1 11 1 2 0. 1. 0. CBAR 2 11 2 3 0. 1. 0. CBAR 3 11 3 4 0. 1. 0. CBAR 4 11 4 5 0. 1. 0. CBAR 5 11 5 6 0. 1. 0. CBAR 6 11 6 7 0. 1. 0. CBAR 7 11 7 8 0. 1. 0. CBAR 8 11 8 9 0. 1. 0. CBAR 9 11 9 10 0. 1. 0. CBAR 10 11 10 11 0. 1. 0. $ $ Bar Properties $ PBARL 11 12 I + + 2. 1. 1. .1 .1 .1 $ $ Material Properties $ MAT1 12 1.0E+7 .33 .101 $ $ Restraints $ SPC1 100 345 1 THRU 11 SPC1 100 1234 1 SPC1 100 234 11 $ $------8-------8-------8-------8-------8-------8-------8-------8-------8------- 8 $ $ EIGRL Card for Eigenvalue Specification $ EIGRL 10 3 $ $ PARAM Cards: LGDISP & NMLOOP $ PARAM LGDISP 1 PARAM NMLOOP 5 $ $ NLPARM Card $ NLPARM 1 5 AUTO 5 25 PW NO+ + 0.001 1.0E-7 $ $ FORCE Card $ FORCE 1 11 0 500. 1. 0. 0. $ $ ENDDATA Best regards, Blas. ~~~~~~~~~~~~~~~~~~~~~~ Blas Molero Hidalgo Ingeniero Industrial Director IBERISA 48011 BILBAO (SPAIN) WEB: http://www.iberisa.com Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/ |
