Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just a quick note to say, "THANKS!" for these forums...The site is very well layed out and easy to use. Thanks for bringing us together - we need each other."
Geography
msquared48 (Structural)
15 Mar 12 23:16
For a catchment wall for an earth hillside prone to sliding with a 35 to 40 degree slope, how would you normally load the catchment wall for sliding earth?  No large rocks in the matrix, but lots of wet soil and brush/small trees.
Impact factor?
Increased active pressure?
Surcharge load?
Lateral point load at the top of the wall?
Possible project and just trying to see what will most likely be involved in the Geotech's report.
Shotgun answers OK.  Thanks.  bigsmile
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
GeoPaveTraffic (Geotechnical)
16 Mar 12 9:49
Impact loading is possible, depending on the type of slides that normally occur.  From your post, I expect that these are relatively small flow type slides.  In that case some impact factor is likely needed, but this is not the type of slide that I deal with very often.
As for the static loads.  If the purpose of the wall is to just temporarily hold the slide debris, not stabilize the slide, then i would use at rest pressures based on the anticipated "pile" of material that will form behind the wall.
If the goal is to stabilize the slide, then I would calculated the load based on the force required to achieve the desired factor of safety.
Hope this helps.
Mike Lambert
theCorkster (Geotechnical)
19 Mar 12 20:43
Dynamics with a sliding "mass" to establish the force the wall has to withstand?
Close Box
Join Eng-Tips® Today!
Join Us             Close
