A function trisection that finds the root of a polynomial
I need to write a function trisection that finds the roots of a polynomial by breaking the interpolation interval {[a,b] into 3 on each iteration. There are four input parameters, a row matrix with the coefficients of the polynomial, a, b, and the desired error. There are two output parameters, root: the root of the equation and n, the number of iterations. Any help is appreciated.
RE: A function trisection that finds the root of a polynomial
Well you seem to have a pretty complete spec of the requirement there. I usually write down the steps I intend to take as comments and then put code in between the comments.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Homework for sure. The name of the method is a dead give away. (missing)
Why don't you start with the Bisection method. It's efficient, and only takes about 20 lines of code. ...
peace
Fe (IronX32)
interesting, with trisection you are using an interpolating quadratic as opposed to a linear interpolation, that is solved easily enough, for a more detailed explanation you might try
http://www.sciencedirect.com/science/article/pii/S0096300307008946
few of us can afford to browes engineering tips from work these days, good luck
Also good luck viewing that article if you or your institution don't have a subscription...
peace
Fe (IronX32)
oh yeah, pay per view adult entertainment for sure, but that is what it takes unless you do the math yourself,
I guess the alternative is a truncated newton's or secant method
