Need to convert SolidWorks File into a Cam File
Hello,i am new in this foru and have been working about 3-4 yeas now with SW. I am now usingg the 210 Pro edition, and i really need to convert some Parts i buildt from any SW Saved File type into a Cam File,can anyone helpme please? I did not find anything trough the serch funktion here, nor on google about this, and there for i thought goin this forum and ask, so please help
kind regards Lars
RE: Need to convert SolidWorks File into a Cam File
You need a CAM software. We use CAMWorks and Mastercam.
If you use an outside machine shop, find out what file type they like, then save-as from SW, send to them.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Thank you for a fast reply.
Ok, i will see what i have and or will then get the needed attachments. These machines are next door tome in the shop where i am doing an internship in, so i can go to them anytime, the are Matzatrol machines and i believe what the owner said is a EIA File or a plain cam. thank you, also what a friend who also works with SW said, is that you can import a STEP. file into he Program for the machine and it will convert automatically, but i haven't tried that out yet, since i don't understand the language the computer is in on there machine
For our machines here, we simply save the file as a *.x_t file and the CAM software imports it without issue.
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
Many CAM packages can import SW format files, or have a SW add-on to enable that ability.
Just to clarify, I'm using BobCAM as an addin to Solidworks. I can export CAM files, but the machine operator often has to clean up and make some changes. If you have experienced CAM operators, just send them the SWX or parasolids files. They'll take it from there.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
