Straightness
Straightness
Straightness
Is it posible to measure the straightness of a rod by chucking it in a lathe with an indicator in three different locations?  I believe checking runout or total runout is not the same thing as straightness.
  I check a rods straightness on a surface plate with feeler gages, on a CMM, or on an indiron.
RE: Straightness
It's not the same thing but it can be useful none the less.
Our receiving inspection bar "straightness" specification defines 2 support points and 3 measurement points with a few qualifying notes about "short kinks" etc.  Can only be used down to a size that does not droop excessively.
I would not use it on a precision part.
RE: Straightness
The rod I am talking about is to check the alignment of 2 bearings 4 inches apart within .001in.  The alignment rod feature numbers are already established.
RE: Straightness
plain or ball?
Is this an axial straightness exemption from perfect form at MMC?
Frank
