ISO column cap with uplift, splice condition
In designing a beam/column connection at a covered walkway, I end up with a net uplift on my 6x12 beam.  The walkway is long, so they is no possibility of using a continuous beam the entire length- there will be a splice condition with two 6x12's abutting over a column.
Naturally, I want to spec a Simpson CCQ or a USP KCCQ, but both manufacturers have identical footnotes "uplift values do not apply to splice condition".  Thanks a lot, manufacturers.
I could detail some ugly, multi-strap/bucket/clip connection, with everything interfering with one another, but surely, there's a connector out there, or some simpler solution.  Ideas, anyone?
RE: ISO column cap with uplift, splice condition
I am not sure about a connector out there that would accomplish this, others might though.  In cases like this though, were you cannot have an ugly strap up and over the beam splice down to the supporting column, I design a custom CC type column cap (bolts instead of nails).
Usually, it involves placing the bolts higher and more outward to achieve bolt end and edge clearances, per the NDS, to allow for the uplift to be resisted.
Of course this costs more, and probably won't make you any friends, but if visual expectations outweigh the cost impact then it's the way to go.
Otherwise you could use a standard CC cap and weld an inverted CC together to hold the beam ends down.  However, a CC upright and inverted will leave a bit of space for a 6x12 beam to move up, this gap will need wood infill.
We do the same - we use 3/16" or 1/4" steel side plates welded with a cap plate to form a "U" shaped assembly that is shop welded to the column and then provided with holes for through bolts in whatever arrangement we need.
