IF statement which test a variable text string?
I am having difficulty with the following IF scenario:
IF PTC_MATERIAL_NAME=(==?)STEEL   (material steel & aluminum have been assigned in setup, as have the steel & alum spring rates as variable values)
SPRING_RATE=SPRING_RATE_STEEL
ELSE
SPRING_RATE=SPRING_RATE_ALUMINUM
ENDIF
I realized my syntax is bad with the initial IF statement, so what should it be if you don't mind responding?  IF PTC_MATERIAL_NAME='STEEL'  OR  IF PTC_MATERIAL_NAME=="STEEL" or something similar.
Thanks....Mark
RE: IF statement which test a variable text string?
This should be the format for the initial iF.
Ben Loosli
Thanks Ben; it worked when I placed entire IF statement as 1 line, but ElSE(& nothing else) had to be on its own line with the condition/equality to follow on the next line....if this makes any sense.
Mark
Yes, that is the way it works :)
IF <parameter1> == "string1"
<parameter2> = "string2"
ELSE
<parameter2> = "string3"
ENDIF
string# could also be numeric values.
Ben Loosli
thanks very much Ben.  1056 instances of a generic (spring)worked very well for different materials.
Mark
