What is a Dual Frequency cycloid?
I'm a mechanial guy working on a roller mechanism, and read that my mechanism uses a "dual frequency cycloid form."
What does this mean as far as the geometry is concerned?
What is a dual frequency cycloid? I understand a cycloid, but am failing to understand dual frequency.
Is it two seperate paths, or 1 that is driven by a dual rate speed?
RE: What is a Dual Frequency cycloid?
There are cycloid drives that are used in sediment separators. They provide a high speed drive to in inner and outer component with a small but high torque speed difference between inner and outer. Two motors running at slightly different speeds are used - maybe this is the dual frequency bit?
If you Google "decanter centrifuge" you will see the idea...
M
Dr Michael F Platten
