Vertical Turbine Pumps
Anyone famililar with Vertical turbine water flush application with an enclosing tube?
I am trying to get information as to the design and operation.
I am familiar with Oil lube, however I was told I needed S.S. lineshaft for water-flush (which seems reasonable) and that I will need pressurized water into the tension bearing for lubrication. What kind of pressure at what volume?
RE: Vertical Turbine Pumps
Why not ask the pump supplier / manufacturer ??? for their guidance .
API 682/ISO 21049 standards have default (required) connections and connection symbols for seal chamber and gland plate connections based upon the seal configuration.
Johnny Pellin
The info given by the OP at this stage is too limited to make any meaningful recommendations
If memory serves, the shaft is 416ss, and the bearings are bronze.
I don't know if I have any info on required flush volume/pressure, I'll see what I can find. After some more coffee.
Thank you an information you may have would be great.
Johnny Pellin
If your pump discharge pressure is greater than the enclosing tube pressure (likely) you may need:
* a throttle bushing and flush ports to discharge the flush water into the pit/well (this keeps pumped product from entering enclosing tube) OR
* a balanced impeller (for single stage) so that flush water can discharge into the pump on the backside of the impeller OR
* some other way to discharge the flush water
If you have a tail bearing, you may need some tubing or a rifle-drilled shaft to provide water flush.
For operation: I recommend flush water flow meters and pressure gauges. Obviously establish flush water flow before starting pump.
The fact is that Water-Flush enclosed tube applications are becomming more in use because of contamination issues with the oil in contact with water.
JJ, I am surprised that you set open lineshafts water lube V.T as deep as you do, I would not reccomend it past 200' because of the pre-lube issues, however if you pre-lube for 15 mins. before you start it must be O.K. however most people would not have that kind of dedication and I would be replacing pumps left and right.
I was trying to get feed back on other types of systems out there.
Typically a water-flush V.T deepwell pump uses the same equipment as oil lube except the lineshaft is S.S. instead of 1045 and the bearing grooves are bord a little deeper to allow water to flow more freely from .125" to .188" deep grooves cut. Also water should be injetted into the tube through the existing tension bearing at a pressure of 10-15psi.
This is the system we are currently using.
Thank you
