vendor for thermal insulation between steel beam and hot equipment
i'm looking for a vendor that do this thermal insulation. equipment goes upto 1000 deg F.
i need to separate the heat from equipment saddle/support to the steel beam.
i've googled around either they dont go up to 1000 deg F or they dont supply bolts/washer insulation with themal insulation pad.
