How to determine Horzontal frequency of a system
I have a vibrating screen that is mounted on springs which are supported by a steel structure. I am only interested in the frequency of the screen/spring system. I use the formula
3.13*√(k/w) for the vertical frequency of the screen/spring system. Now I need to calculate the horizontal frequency of the system but do not have a references or guidance to calculate. Please provide some guidance in regards to calculating the horizontal frequency.
RE: How to determine Horzontal frequency of a system
Cheers
Greg Locock
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
I am looking for a formula to calculate the horizontal frequency of a system. I have the formula for the vertical direction which is posted above.
btrueblood
What are you talking about by points??
Twoballcane
Are you saying that the equations are the same for the vertical and horizontal as long as the stiffness of the springs are the same in horz & vert?
Cheers
Greg Locock
Tobalcane
thanks for the reply. same equation you posted just reduced.
(1/2pi)*√386.4=3.13
