Section Callout -drafting-macro
Hi Everybody,
I want to change the size and thickness of Section Callout arrow
I tried with the Admin mode , but the drawing was not changed.
Is there any macro for changing the same.
Pls Any Help will be appreciated,,
Thanx in advance ....Pls Help
RE: Section Callout -drafting-macro
Hello Enigma,
Right-click on Callout feature> Properties>Callout tab
and you will be able to change the Length, Thickness Arrow-Head Thickness and Arrow-Head Angle....
I hope it helps.
-GEL
