NFE 32-101, 102, 103 French Boiler Code: have a copy or know about it?
We have a boiler designed to a french boiler code:
Code de construction des générateurs de vapeur
We're particularly interested in part 103:
NFE 32-103 Code de construction des générateurs de vapeur - Partie 3 : Calcul de résistance des éléments soumis à une pression intérieure
as this is for the design calculations.
Is anybody familiar with it? If it's been superseded then does anyone know what it's been superseded by? I'm assuming it's now an EN code?
Cheers
Adam.
Cheers
Adam.
Adam Potter MEng CEng MIMechE
www.ax-ea.co.uk
RE: NFE 32-101, 102, 103 French Boiler Code: have a copy or know about it?
it may be have superseded by NF EN 12952.
The french code COVAP seems to cover this application.
h
You can have a look at this page to see which European standards may fit your application (boilers) and then look for the french nationalised version of those standards.
yours,
You will have to sit down and spend the same amount of time that I did back then and also get an English French Technical dictionary.
well I wanted to put the following web site adress in my previous post:
h
It is a list of standards which that you can use to have presumption of conformity to the essential safety requirements of Directive 97/23/EC for Pressure equipment.
the EN 12952 Water-tube boilers and auxiliary installations with all its sub-parts is included.
yours,
Thanks to the boys at IHS I've managed to locate a copy and it'll be here next week!
Many thanks for your comments.
Adam.
www.ax-ea.co.uk
