Global change of mtext style including blocks?
I have many drawings that use blocks for individual references. They have a txt font I would like to change to romans. I can easily do it by opening the block in the editor and making the change. What I need is a global tool that will change ALL mtext fonts at once, including the blocks. How can I do this?
Frank
One test is worth a thousand expert opinions. - Dan Joos, test engineer
RE: Global change of mtext style including blocks?
Copy the romans.shx file to txt.shx.  Autocad will now display all txt style text as romans.
Thanks! That worked very well.
Frank
