Batch Area Calculations in AutoCAD
I am using autocad to find areas of a stream cross section such that when we take a water height measurement of the stream in the field, we can easily get the area from a spreadsheet since the cross section of the stream at any height will be known (once I get done in AutoCAD).
To further illustrate my needs, I have attached a picture. I need all the seperate areas between the red lines (the red lines are equally spaced vertically and have lengths that go end to end to the edges of the stream).
I have been hatching between the red lines and taking the areas of each hatched object. However, this is a slow and tedious process.
Hatching is not the issue because I can hatch multiple objects at once using the create seperate hatch option.
What I need is a way to list all the hatched object's areas into a text file so that I can easily copy and paste them into an excel file. Even if it is not a nice and neat list, I can atleast use a find for "area" to get them into a nice list a little faster.
Any Ideas?
Myles
Any Ideas?
Myles
RE: Batch Area Calculations in AutoCAD
(I couldn't download your attachment).
