Updates entire top assembly after doing a sketch
Why does my NX seem to update everthing after I finish a sketch, is there a preference I am not seeing, it's updating things that has nothing to do with the part I am sketching on, is there a setting in customer default that i'm not aware of, any help would be great I am running NX8.
RE: Updates entire top assembly after doing a sketch
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Note that I used an Assembly that I have which goes several levels deep and in fact includes WAVE-linked parts and no matter at what level I edit a sketch, be it one, two, three even four levels below top level Assembly, the only parts which update as a result are the ones that your would expect, the edited part, and if there are WAVE-linked 'children', they update as well, but that's all. Note that I tested this with loading the assembly with both 'Partial Loading' ON and OFF, as well as 'Load Interpart Data' (all levels), and there was no differences.
Question: has all of the parts in this Assembly model been updated to NX 8.0 using the 'refile' utility? Have you opened the Assembly and then done a 'Save All'?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Information -> Part -> Loaded Parts
...while you have your assembly loaded and check to see if all your parts have listed as being NX 8.0. If there's only a few which are not, you could simply set them to be the work part and then hit the Save button.
John R. Baker, P.E.
Industry Sector
Cypress, CA
