Double vs Twin vs Identical Components. What is the right terminology?
I have two components which have different part number, exactlly the same geometry and made of the same material.
What is the most appropriate term to be used?
-Double Components
-Twin Components
-Identical Components
Thanks in advance.
GEL
-Double Components
-Twin Components
Thanks in advance.
GEL
RE: Double vs Twin vs Identical Components. What is the right terminology?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
At a previous employer we had 2 similar product lines but for different government offices/desk officers.
Some of the parts were functionally common but because of the different contracts etc. covering the 2 product lines couldn't be the same number. If the part had to be revised, then one office might not have wanted to pay for the revision to be taken up through the drawing pack/drawing list.
In this case 'equivalent' components was perhaps a better term.
(Of course there was a counter argument to this whole situation if revision really meant revision or assigning a second pn only when the parts diverged etc. but that's for another day.)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
And to KENAT's comment, yes! In many instances, they should be the same part number, but there are many cases where they should not be.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
I really appriciate your prompt response to my question. Thank you all.
Last year I was working in a Structure Design Project and at the Detailed Design Phase of it I realized that we had a lot of X components (where X=Double/Twin/Identical/Dublicate/Same As/....) due to the "Skeleton-Dress Up method" of the used CAD system (one of the two major in the market).
So, more or less MadMango is right. Having X components is a waste of user time, computer resources and slows down the CAD system.
Due to this I decided to develope a method and a CAD add-on application which at the end of 'Transitional Phase Design' will eliminate any selected (or all) X components by replace them with the master one and all this without any effort from user side. Now having finished this application I'm looking for a proper name for it.
So, what is the right name for this application? Double Components Manager?/Twin Components Manager?/Dublicate Components Manager?/Same As?/...?
-GEL
Duplicate Destroyer
Un-Duplicator
Is your utility similar to http://www.3dpartfinder.com/en/Home.aspx
Doesn't mean there isn't a better option though.
Although, as a personal title, I like "Un-Duplicator".
especially if you say it with a German accent like AHHHHNOLD.
"I'll be BAAAACK to check your PAAAAAT NUMBER"
You can call the application "Against similarity App" or in short ASA. If you want you can call it "App Against Similarity", you can work out the acronim for that.
though similarity isn't the best word here I think.
NX 7.5
Teamcenter 8
I'd name it Tower of Babel.
carry on. . .
f-d
¡papá gordo ain't no madre flaca!
Double - can be doubled components in an assembly, hence potentially ambiguous.
Twin - not always truly identical.
Identical - would truly be the same including part number.
"Duplicate" is used in collecting circles, i.e. stamps, money, ephemera, where multiples exist of the same item perhaps with different numbers or other marks.
However, in this situation, I've seen both "revision" and "iteration" used, even though only the part number is what was iterated or revised.
Why not "equal" or "equivalent"?
eg the NEC 7201 and Intel 8274 MPSC are the same chip functionally. The package is the same size, the pinouts are the same. You could say the NEC 7201 is a second source of the Intel 8274.
1. Have been designed in the CAD system as two separate Parts or Assemblies by the same or different designer.
2. Due to the use of Mirror command.
3. Part of the design has been subcontracted.
Intentional : Equivalent or Alternative
