Modeling damage in abaqus
Is there any difference between modeling material damage using abaqus/standard +user routine (usdfld) and abaqus/explicit?
thanks in advance
RE: Modeling damage in abaqus
Depends on the problem, is it impact based? If so you might want to use Explicit instead of standard. Check the abaqus manuals, too, sometimes not all subroutine features can be used in Explicit.
Thank you yaston4, my problem is not impact based, it is about modeling failure of lap-joint (static test)
