PC to HD TV Screen.
PC to HD TV Screen.
PC to HD TV Screen.
I have a PC running Windows 7.  It has a PCI graphics card with both a VGA port and a HDMI port.
When I switch the PC on if both cables are plugged in I see no screen activity, if I subsequently try either cable the PC doesn't appear to have successfully booted although it is on.
The only was I can get the HD I want is via the following procedure:
1. Connect VGA only
2. Boot up & login.
3. Plug in HDMI cable
4. Unplug VGA Cable.
I've tried the above in varying order etc, this is the best result but I obviously don't want to keep hot swapping the cables.  Plus the PC will be in a slightly awkward spot to reach once running how I want it.
RE: PC to HD TV Screen.
Thank you Dan,   That explains why there was no similar material.  Apologies.
