grips & Multi objects ribbon display
when I pick grips and select objects the autocad menu ribbon disappears and muti objects ribbon then appears. Why and how to eliminate
RE: grips & Multi objects ribbon display
How are you picking your "grips"? Are you selecting the object by clicking on it or draging the mouse to box the object?
Or am I way off?
Jeffery V C.E.T.
"If Brute force doesn't solve your problem, your not using enough"
