Member fuction lateral and gravity
Hi all,
Just want to know if what exactly is the effect when you specify the member as lateral or gravity on the function option..
RE: Member fuction lateral and gravity
The function is ignored unless the member is being designed per AISC's "Direct Analysis Method".  If the member if defined as lateral, then it will receive stiffness adjustements per that method. If it is defined as gravity then it will not receive those adjustments.
The idea is that if the member does not participate in the lateral force resisting system (say a simply supported beam for example) then there is no need to reduce the stiffness of the member to account for the DAM stability effects.
