dealing with broken assembly constraints
(NX8)More a handling problem:
I have opened a assembly has some broken (errors) with assembly constraints. I want to fix these problems. What is the quickest way to determine and to solve these problems. Some tricks ?
thanks in advance
thanks in advance
RE: dealing with broken assembly constraints
Less faster = double click on the error constraint then you will see which datum/face/edge/.... is still selected and then reattach it to the second csys/datum/edge/.... click apply.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
How do you handle the deactivated constraints?
kill em all?
Best regards,
Michaël.
Win 7 64 bit
