flow resistance of 3 way ball valve
Hi All,
Not sure if this is the right place to ask this question.
For a 3 way L port ball valve reduced bore. what flow resistance factor should I use?
Should I simply threat it as a straight reduced bore(k1) + a 90 degree bend(k2)?
So as per Crane T410 paper, K=K1+K2, where K1=formula 5 or 6 given in A-28, and K2=60fT?
Any comment on this?
Spoonful.
Spoonful.
RE: flow resistance of 3 way ball valve
I'd likely do it as a combination of a reduction from the line to the ball ID, the change in direction within the ball (likely as a tee with the flow through the branch) and then the expansion back to line size (if the latter loss is applicable).
From "BigInch's Extremely simple theory of everything."
I don't think my supplier would be at much help,
your way of model it which is pretty much the same as my :
a reduced bore ball valve K1 + a 90 degree mitre bend(to be conservative rather than threat it as elbow) K2,
so total K=K1+K2
so dP= density*k*velocity^2/2
BigInch,
I don't quite understand you way. dP during switch is not what I am after, I am only looking for at one fully open 90 degree position dP.
BTW, dose any one have knowledge of
I.E. Idelchic - Handbook of fluid resistance, Diagram 8-3, perforated thick plate dP, I am trying to use the method given, but it seems my manual calculation result could not match these given in the graph.
Thanks for all the comments
Reynold
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
I would like to use a full bore as for less pressure drop. but I found it hard to find a full bore for 50NB.
A full bore 3-way ball valve is virtually impossible because there isn't enough metal left to have a sufficiently strong ball. If you want a full bore 50NB valve it probably means that you will have to install an 80NB reduced bore valve.
Katmar Software - Engineering & Risk Analysis Software
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
