flow resistance factor for 2 way L port ball valve
Hi All,
Not sure if this is the right place to ask this question.
For a 3 way L port ball valve reduced bore. what flow resistance factor should I use?
Should I simply threat it as a straight reduced bore(k1) + a 90 degree bend(k2)?
So as per Crane T410 paper, K=K1+K2, where K1=formula 5 or 6 given in A-28, and K2=60fT?
Any comment on this?
Spoonful.
Spoonful.
