3D SRS Anaylsis using Lusas
Hey guys,
I am trying to get to grips with seismic SRS analysis using Lusas,
I have run through the examples in the manual, however the question I have is with a 3D srs anaylsis can you specify a different SRS curve for each  direction? Then can you combine the results in each direction using an appropriate method to obtain a single set of results?
Thanks in advance
Matt
