ASTM A 923-06
ASTM A 923-06
need a littel help here, looking at a project which requires addional testing for qualification of a WPS , specs reference A923-06 , material will be UNS S 32205(Alloy 2205) & UNS 31803 , I find a reference to A923 which list three test method a,b,c, any help thanks
RE: ASTM A 923-06
Ok, between the three test methods you have chemical etching, Method A, impact testing, Method B and corrosion testing method C.
My preference would be Method C, corrosion testing because corrosion performance is probably the reason for selection of these materials for service.
Make sure you work closely with a reputable material testing lab.
RE: ASTM A 923-06
RE: ASTM A 923-06
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
RE: ASTM A 923-06
Method C looks like a corrosion test, but it is quite different from G-48, all that they share is the test solution.
Plymouth Tube
