Correct References in Workgroup PDM Vault But incorrect on local disk
Hi all,
I have an assembly (69645-1) that is saved in the workgroup PDM (Vault).
When I RMB on this assembly and pick <Document Information>-> <Refernces Tab> it contains references to various parts. One of these parts is a Bearing stored in the "Bearings" folder of the workgroup PDM. for completeness sake is part number SR2ZZA1P25LD.SLDPART.
I open and check out 69645-1.
Now.... In solidworks I select File -> Open and navigate to 69645-1 on my local E:\ drive. If I select the part in the "File->Open" Dialogue box and then LMB <References...> it contains incorrect references and locations of the bearing mentioned above.
The window contains "Instrument Ball Bearing_AI.sldpart) (a toolbox part) located in Folder C:\Solidworks Data... instead of the proper SR2ZZA1p25ld.sldpart located on my E:\ drive.
Summary: The references are correct in the vault but get screwed up after I bring the part to my local drive. I can fix them by double clicking and pointing Solidworks to the correct file, but I would prefer to not have to do that for every assembly in my vault with screwed up references.
Has anyone else experienced this problem?
Frank
Frank
RE: Correct References in Workgroup PDM Vault But incorrect on local disk
Somewhere in those files it remembers they were once a toolbox part, and can go into your toolbox to find it again (back to the orinial, unmodified version).
check out: https://forum.solidworks.com/thread/39263
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Only question is how to figure out which toolbox...
I took over for a couple of guys that didn't understand Workgroup PDM or Toolbox 100%...
Eric
