Orbital Pipe Welding Scheme
Have been out of the fabrication game for some time but getting back into it.  I am seeking advice on the following brief for orbital pipe welding:
MOC: CS, low alloy, SS, including duplex.
Position: 5G and 2G
Quantity: 100/month (guesstimate)
Code: B31.x, ASME VIII
Inspection: 100% X-ray
Looking at both machine and automatic options (as defined by ASME IX).  Must have reasonable productivity and simplicity; i.e., reasonably easy to learn and not too fussy.  Weld preparation requirements should not be onerous - simple preps.
Within the above parameters, I am seeking process and equipment recommendations.
Thanks in advance
RE: Orbital Pipe Welding Scheme
I'll second that one. AMI is my favorite.
Others include Liburdi and Astro Arc.
Tri-Tool makes good simple prep equipment.
Plymouth Tube
Talk to your local Lincoln rep as well.  They sunk some bucks into their acquisition of Arc Products, and they have developed a VERY slick, very robust orbital head, priced exceptionally well.  I believe it also interfaces with one of their standard inverter power supplies.
Liburdi Dimetrics and Magnetec as well as the above.
