Script to Rename Instances and Keep Contextual Links
Iis that a way to run a VBscript that updates the Instance Names and keep the Contextual Links?
If I manually open Part Properties on a Product and change the Instance Names, a windows pops up and asks to reconnect the Contextual Links. This works fines and keeps the links. However running a VBScript to rename will break all the links to the Assemblies and Drilling.
RE: Script to Rename Instances and Keep Contextual Links
Depend on what your script is doing....but is first time when I hear about this kind of problem, all scripts which I saw about instance renaming were running without this kind of problem.
Fernando
That is what a Dassault engineer told me.
Best Regards,
John Latva
