Draftsight Software
Draftsight Software
Hello All,
Our IT dept said they need to uninstall Draftsight because we need to pay for enterprise version using here at work. Is this true? They said the free download is for home use only.
Please help because I'm in a middle of a project and need this software till I transfe my data into SW.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 Windows 7 Pro (64-bit)
Xeon CPU 2.53 GHz 6.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
RE: Draftsight Software
Dan
www.eltronresearch.com
Dan's Blog
http://www.3ds.com/products/draftsight/services
It's possible CATIA said something to them...been there.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
... but...
I remember acknowledging a longish gobbledygook license agreement, so your IT guys may be right.
If they've asked other than verbally, you probably have little choice in the matter.
Maybe your boss has enough 'juice' to delay the transition from free license to enterprise license until you have completed your project. The IT people themselves probably have knowledge of many such transitions that went badly. They may not admit it if their boss is an ogre. ... which seems to be a common qualification for IT bosses.
Mike Halloran
Pembroke Pines, FL, USA
This End User License Agreement for No-Charge Software ("Agreement") is made by and between Dassault Systèmes SA, 10 rue Marcel Dassault, 78140, Vélizy-Villacoublay, France ("DS") and you ("Licensee").
IMPORTANT – READ CAREFULLY: The terms and conditions below set forth a legal agreement between DS and Licensee relating to the data processing program license distributed with, or otherwise subject to, this Agreement (the "Licensed Programs(s)"). Licensee should carefully read these terms and conditions BEFORE downloading and installing the Licensed Program(s).
1. LICENSE
DS hereby grants to Licensee a no charge, non-transferable and non-exclusive license to use the Licensed Program(s) solely in accordance with this Agreement. Unless otherwise agreed in writing by DS in a separate agreement: (i) Licensee acknowledges and agrees that DS shall have no obligation to provide any services, support or maintenance for the Licensed Program(s) under this Agreement, and (ii) the Licensed Program(s) may be installed, executed and accessed by Users on hardware belonging to Licensee ("Machines"), and may not be executed or accessed by any other means, including without limitation via a network. "Users" include Licensee as well as its employees, students, consultants and subcontractors who access the Licensed Program(s) on Machines. Licensee may make the necessary number of copies of the applicable Licensed Program(s) for installation and one copy for back-up of each Licensed Program in support of Licensee's authorized use pursuant to this Agreement. No rights including any right to use, reproduce, display, other than those specifically described in this Agreement are granted to Licensee. Except to the extent permitted by applicable law, Licensee shall not analyze for purposes competitive to DS, reverse engineer, decompile, disassemble, or otherwise translate all or part of the Licensed Program(s). In the event Licensee wishes to ensure the interoperability, within the limits of its authorized use as defined in this Agreement, of the Licensed Program(s) with other computer software or with equipment under conditions provided for by law (including without limitation laws implementing the directive 2009/24/EC of the European Parliament and of the Council of 23 April 2009 on the legal protection of computer programs), Licensee must ask DS for a license to use standard interfaces, exclusively for internal use to achieve interoperability. DS will grant Licensee a license to use the standard interfaces at the then current prices and contractual conditions of DS or, if standard interfaces are not available, DS, for a fee, may provide Licensee with the necessary information to permit interoperability. Licensee is not authorized to give access to these interfaces to any person other than Users.
2. TERM & TERMINATION
This Agreement shall come into full force and effect upon Licensee's acceptance of these terms and conditions, which acceptance is indicated by selecting the "Accept" button in the dialog presenting this Agreement, by downloading and/or installing and/or using the Licensed Program(s), and/or by your acceptance of another agreement that references and incorporates this Agreement, whichever occurs first. This Agreement may be terminated at any time by DS for any breach hereof upon notice to Licensee. Periodic activation may be required by Licensee in order to continue use of the Licensed Program(s). Use of the Licensed Program(s) may be interrupted until necessary activation steps are taken by Licensee. Upon termination hereof, Licensee shall immediately uninstall and delete all copies of the Licensed Program(s) and discontinue use of the Licensed Program(s). The sections entitled "PROTECTION AND NON-DISCLOSURE", "WARRANTY AND DISCLAIMER OF WARRANTY, RISK OF USE, LIMITATION OF LIABILITY AND INDEMNITY" and "GOVERNING LAW AND JURISDICTION" shall survive termination of this Agreement.
3. PROTECTION AND NON-DISCLOSURE
The Licensed Program(s), including any copies made by or for Licensee, in whole or in part, are the sole property of DS or its licensor(s). All intellectual property rights in the Licensed Program(s) belong exclusively to DS or its licensor(s). DS and/or its licensors shall retain all title, copyright and other intellectual property rights in the Licensed Program(s) and all modifications, enhancements or other works derivative of the Licensed Program(s).
Licensee shall preserve and reproduce any copyright, patent and trademark notices which may appear in the Licensed Program(s) on all copies thereof, in whole or part. Licensee shall keep full, true and accurate records of all copies of the Licensed Program(s), which records shall be available for audit by DS.
Licensee recognizes that the methodologies, techniques, expressions, ideas and concepts contained in or expressed within the Licensed Program(s) are proprietary information and trade secrets of DS or its licensor(s). Licensee shall treat them as confidential information and never disclose them.
4. LICENSEE'S RESPONSIBILITIES
Licensee is solely responsible for supervising, managing and controlling the use of the Licensed Program(s) in compliance with this Agreement, and shall take all appropriate measures, including with Users, to ensure such compliance, including without limitation compliance with its authorized use, and confidentiality obligations. Export to Licensee of Licensed Program(s) is subject to all applicable countries' export and re-export laws and regulations. DS shall have no liability whatsoever towards Licensee if such authorizations, licenses or approvals are not obtained. Licensee shall not export or re-export, either directly or indirectly, Licensed Program(s) when such export or re-export requires an export license or other governmental approval without first obtaining such license or approval. Licensee hereby certifies to Licensor that the Licensed Program(s) ordered hereunder will not be used in any nuclear, chemical, biological, weapons or missile delivery systems and will not be diverted to any country, company or individual that is prohibited by the applicable export laws of any country.
5. WARRANTY AND DISCLAIMER OF WARRANTY, RISK OF USE, LIMITATION OF LIABILITY AND INDEMNITY
THE LICENSED PROGRAM(S) ARE MADE AVAILABLE ON AN "AS IS" BASIS, AND WITHOUT WARRANTY OF ANY KIND, WHETHER EXPRESS OR IMPLIED, ORAL OR WRITTEN, INCLUDING WITHOUT LIMITATION THE IMPLIED WARRANTIES OF MERCHANTABILITY, TITLE, NON-INFRINGEMENT OR FITNESS FOR ANY PARTICULAR PURPOSE, AND ALL SUCH WARRANTIES, CONDITIONS, UNDERTAKINGS, AND TERMS ARE HEREBY EXCLUDED TO THE EXTENT PERMITTED BY LAW. IN NO EVENT SHALL DS OR ITS LICENSOR(S) BE LIABLE FOR DIRECT OR INDIRECT, CONSEQUENTIAL, SPECIAL, INCIDENTAL OR PUNITIVE DAMAGES, INCLUDING LOSS OF USE, PROFIT, REVENUE, OR GOODWILL, WHETHER BASED IN CONTRACT, NEGLIGENCE, OR OTHERWISE, ARISING OUT OF, RESULTING FROM OR IN ANY WAY RELATING TO LICENSEE'S USE OF THE LICENSED PROGRAM(S), INCLUDING, WITHOUT LIMITATION, LOSS OF PROFITS, LOSS OF DATA, OR LOSS OF USE DAMAGES ARISING OUT OF THIS AGREEMENT OR THE SUPPLYING OF THE LICENSED PROGRAM(S), EVEN IF DS OR ITS LICENSOR(S) ARE AWARE OF OR ARE NOTIFIED OF THE POSSIBILITY THEREOF. THIS SECTION SHALL SURVIVE ANY EXPIRATION OR TERMINATION OF THIS AGREEMENT. LICENSEE'S USE OF LICENSED PROGRAM(S) SHALL BE AT LICENSEE'S SOLE RISK. LICENSEE SHALL INDEMNIFY AND HOLD DS HARMLESS FROM ANY AND ALL LIABILITY OR EXPENSE, INCLUDING REASONABLE ATTORNEYS' FEES, ARISING OUT OF THIS AGREEMENT OR LICENSEE'S USE OF THE LICENSED PROGRAM(S) UNDER THIS AGREEMENT.
6. GOVERNING LAW AND JURISDICTION
Except as expressly permitted herein, this Agreement may be modified only by written amendment signed by the parties and no other act, document, usage or custom shall be deemed to amend or modify this Agreement, including but not limited to Licensee's terms and conditions. The Agreement shall be governed and construed in accordance with the laws of France. The Commercial Court of Paris ("Tribunal de Commerce de Paris") shall have exclusive jurisdiction to hear any dispute arising out of or in connection with the interpretation and/or performance of this Agreement, however, the parties acknowledge and agree that in the event that the subject matter of any such dispute is intellectual property, DS shall have the right to bring any such dispute before the French Civil Court having jurisdiction pursuant to the French Code of Civil Procedure ("Code de Procédure Civile"). Licensee acknowledges and agrees that the last two sentences above shall not prevent, restrict or otherwise limit in any manner, DS' rights to seek equitable remedies, including injunctive relief before any competent court in any jurisdiction.
7. U.S. GOVERNMENT RESTRICTED RIGHTS
If Licensee is an agency or unit of the U.S. Government, or obtains the Licensed Program(s) for the benefit of the U.S. Government, the Licensed Program(s) and the related Documentation are "commercial items," specifically "commercial computer software" and "commercial computer software documentation," and, consistent with FAR 12.212 and DFARS 227.7202, as applicable, are licensed to Licensee only with those rights as are granted pursuant to this Agreement. This provision shall survive any termination or expiration of the Agreement.
Dan
Dan's Blog
The Premium Pack is an extension of the individual/standalone version to give enterprises and educational institutions networked software deployment, customization and technical support.
See here for more details;
http://www.3ds.com/products/draftsight/overview/
Best,
Mechanical Designer
>even if you are right and they are wrong<
arguing with IT can be a career decision.
Only you know enough about your environment to tell.
Mike Halloran
To be sure, why not contact Dassault and ask?
http://www.3ds.com/contact/
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
1) Called my VAR
2) Called SW
3) Called Dassault (CBL's idea)
All 3 said it's ok to download/install standalone on business computers or any computer.
Thanks for all the help!
Mechanical Designer
