Lifting shackle bow nut bolt blue pin 13.5
Hi guys,
I was wondering if I have a shackle of pin diameter 39mm to be used on lifting equipment on construction sites, what sort of diameter would it require ? is there any guidance to that ?
At the moment I am using 41mm. is there a range of play allowed and safe ?
Thank you kindly
ethan
Thank you kindly
ethan
RE: Lifting shackle bow nut bolt blue pin 13.5
Not sure but this might help:-
htt
Petrotrim Services
www.petrotrim.com
Get the official versions by downloading the pdfs from dnv.com.
Get their pub list here:
http://www.dnv.com/binaries/PubList_tcm4-10019.pdf
Mike Halloran
Pembroke Pines, FL, USA
