Handling Cancels in Directory Dialog
I have tried this in two different ways.
CODE
      Try
         Dim dialog As new FolderBrowserDialog()
         dialog.description = "Select Directory containing loft data."
         strDir = dialog.ShowDialog()
         strDir = dialog.SelectedPath
      Catch E As Exception
         MessageBox.Show("Program cannot continue without lofting data location.", "Error", _
               MessageBoxButtons.OK, MessageBoxIcon.Error)
         Exit Sub
      End Try
As well as
CODE
      On Error GoTo DirCanceledError
      DirCanceledError:
         '   If the user cancels the Directory Form, Exit the program
      Exit Sub
The first has no reaction when the cancel button is used and the second hits the error regardless of whether the cancel button is hit or not.
Any help with this would be greatly appreciated.
RE: Handling Cancels in Directory Dialog
Check the dialog result and do something based on it. The example below simply exits if cancel is pressed.
CODE
Dim FolderBrowserDialog1 As New FolderBrowserDialog
' Then use the following code to create the Dialog window
' Change the .SelectedPath property to the default location
With FolderBrowserDialog1
    ' Desktop is the root folder in the dialog.
    .RootFolder = Environment.SpecialFolder.Desktop
    ' Select the C:\ directory on entry.
    .SelectedPath = "C:\"
    ' Prompt the user with a custom message.
    .Description = "Select the directory to export .dxf file(s)"
    If .ShowDialog = DialogResult.OK Then
       strOutputFolder = .SelectedPath
   else
       exit sub
    End If
End With
www.nxjournaling.com
