Insert chamfer dimension
In drafting, the software allows me to insert a chamfer dimension for chamfers that are 45 degrees (insert =>dimension =>chamfer) however the command is not intended for angles other than 45 degrees. Is there another tool that allows us to call out a chamfer other than 45 degrees? I would like the callout to be tied to the model such that if I change the chamfer in the model, the drawing updates...
RE: Insert chamfer dimension
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Technically, the glass is always full.
