Available Fault MVA from separate source
Consider: Two separate 69kV lines feeding two 12.47kV lineups through 20MVA transformers. The lineups are connected through a N.O. 1200A tie breaker. The fault duty at one lineup is 100MVA and 105MVA at the other lineup. If conditions on one line are inadequate the load will be transferred to the other line in a closed transition process.
What is the fault duty at the interconnecting breaker during the closed transition process when the tie breaker is closed?
RE: Available Fault MVA from separate source
