Elevated Temperature material properties for SA516
3
Can anyone guide me toward where I can find stress/strain curves for SA516 gr 70 at elevated temperatures?  I am working on a non-linear analysis and need these properties.  Thanks in advance.
RE: Elevated Temperature material properties for SA516
Not sure you will be able to find stress strain curves at elevated temperature. Why not use ASME B&PV Code, Section II, Part D, Tables U (Tensile Strength Values) and Y (Yield Strength Values) as a function of service temperature?
How elevated is the temperature?  Specificity will help us help you.
Temperature is 1,000 deg F.  I will look into Section II, part D and see if that will work.  I am attempting to prove that the peak stresses of my FEA will relax and are not areas of concern.  There is some debate as to where local primary stresses become peak stresses.
You're well into the creep regime.  I would suggest that you create a isochronous stress-strain curve, using one of the methods in API-579/ASME FFS-1.  The difficult part will be choosing the time to use in the calculations.
Thanks, I will look into API-579; I think the desired life is known.
One more question on this same subject if you don't mind.  I have read in the code that stresses a distance of SQRT(R*t) away from a peak should be considered local primary.  If the peak stress are caused by a strap on a vessel, what distance should be used?  Would R be half the width of the strap or would R be the radius of the vessel?
What you interpreted with respect to local primary and 1.0*sqrt(r*t) is incorrect.  What the Code says is that, for a primary membrane stress to be considered local, the extent to which it exceeds 1.1*S must be less than 1.0*sqrt(r*t) in the meridional direction.  It is possible that one could have a surface stress that exceeds the linearized membrane-plus-bending stress, and that stress would be considered "peak".  Coincident to that, you could also have the membrane stress be either primary local or primary general.  It's sort of an apple and oranges thing...
Note that if you are trying to determine if stresses will relax (creep), then you are doing a non-linear analysis.  DO NOT linearize any results from a non-linear analysis...
I have gone back and read the code, but I still am not confident that I understand this.  Is it true that a stress greater than 1.1S that is > sqrt(r*t) from a discontinuity should be considered a Pm?  Maybe another way to say that is a stress that exceeds 1.1S and is greater than sqrt(r*t) from a discontinuity would exceed the allowable limit.
Are the surface stresses (peaks) governed by 1.5S or 3S?
Is there a distance similar to sqrt(r*t) that defines a hotspot stress?  For instance if the stress extends a certain distance it should be considered a local primary, or is this engineering judgement?
I really appreciate everyone's help on this.  I believe I am getting close to understanding Part 5, but there are a few issues like this one I need to work out.
Quote (McT178):
In short - maybe, but remember, we are ONLY talking about membrane stress, in this context.
Quote (McT178):
No.  A membrane stress may be classified as local if the extent to which it exceeds 1.1S in the meridional direction is greater than 1.0*sqrt(r*t).
Quote (McT178):
No - they are governed by the fatigue rules.
Quote (McT178):
No.  Your membrane stresses will either be classified as general primary membrane (Pm), local primary membrane (Pl), or secondary.  The through-thickness bending stresses will either be primary bending (Pb) if it is in a flat head, or secondary.  Anything that exceeds the linear through-thickness stress distribution is peak.
Does this help?
I probably should have mentioned earlier that the report I am looking at was created with plate elements.  Is there a determined distance away from a hot-spot where primary local stresses are evaluated and then another distance where general primary stresses are evaluated?
Even in plate/shell elements you still have membrane and membrane+bending stresses.  Evaluate each separately.
As far as how far away from discontinuities you should evaluate the stresses, I would suggest that you take the same approach that you would if you had 3D-solid elements: at the edge of the juncture ring.  For a typical nozzle-type arrangement, that is usually 1/2t (to account for the thickness not being explicitly accounted for in the shell/plate elements) + fillet weld leg.
The good thing about plate/shell elements is that you can directly plot membrane stresses.  Do that, with a contour of 1.1S.  Then, you can directly measure the meridional extent to which the membrane stress exceeds 1.1S.  If that extent is less than 1.0*sqrt(r*t), then the membrane stresses inside that region can be considered local and subject to the 1.5S limit.  If the extent is larger that 1.1S, then the membrane stresses are not local and will fail the 1.0*S check.
My confusion is where a peak (3Sa) becomes a local (1.5Sa).  For example, if I have a peak at a discontinuity, at what distance from that discontinuity would I stop evaluating the stress for 3Sa and start to evaluate at 1.5Sa.  It seems like it might be a common area of confusion because I found another thread (http://www.eng-tips.com/viewthread.cfm?qid=211759) where similar questions as my were asked, but it did not seem to result in a definite answer.  We commonly receive reports where a point a few inches from a peak are named PL and evaluated as so (1.5Sa).  Then the area is evaluated with bending + membrane, and the peaks are evaluated as primary + secondary (3Sa).
Apples and oranges comparison.
The 1.5S check is for MEMBRANE (i.e. mid-surface) stresses.  The 3S check is for MEMBRANE+BENDING (i.e. surface) stresses.  Peak stresses (the ones that are handled in Article 5.5) are those surface that are beyond the M+B stresses.
The M+B stresses should be evaluated at the same locations that I indicated in my previous post.
And don't get to confused about primary vs. secondary.  First you have to figure out whether it is membrane or M+B.  That seems to be the problem to start...
Is setting the software to membrane only and then setting it to membrane + bending enough differentiate the two?  What about peak stresses at discontinuities when the software is set to show only membrane stresses?
Quote (McT178):
Yes.  That is exactly what you need to do.
Quote (McT178):
You won't find "peak" membrane stresses.  Don't bother looking.
In fact, you won't find "peak" stresses (generally) in a shell-plate element analysis.  The formulation of the shell-plate element is such that it ASSUMES a linear through-thickness gradient in stress - the exact definition of M+B.  If you want actual "peak" stresses that you will evaluate in a fatigue analysis, you will either have to factor your M+B stresses by an SIF, or perform a 3D-Solid FEA.
Ok, think I got this.  A highly localized stress at a discontinuity (corner of strap welded to vessel for instance) should be evaluated as a primary local membrane (1.5S) when the FEA is set to membrane only, and then if set to membrane + bending, evaluated as a peak (3S).  If that statement is correct then I believe I understand this.
TGS4;
Nice job with staying on this and the detailed explanation.
McT178 - you got it.  With the proviso about how close to the discontinuity you should look.
metengr - you're welcome.
Yeah...Thanks a lot for taking the time to walk me through this.  Another step on my never ending quest to understanding ASME Sec VIII!
I suppose A516 Gr70 can not be used at temperatures above 343ºC.
LM
It can be, but creep needs to be considered.
