Controlling other expressions with one expression
Hey, is there a way that I can use an if statement, and if p3=1, it will change p4 to 7 and p5 to 9, and if p3=2, it will change p4 to 3 and p5 to 12?
RE: Controlling other expressions with one expression
Sure, can you get onto the NX doc? If you can then look up "conditional expressions"
Maybe do a search in here for those two words too.
You will be able to write an "If-Then" statement for those.
I really wasn't able to find anything like I am talking about, I dont think.
I kind of want to add an expression like this
if(test=1)(e=32 & q=23) else (e=36 & q = 58)
Does that clarify any?
Using IF statements, your set of expressions would look like:
p3=1
p4=IF (p3==1) THEN (7) ELSE ( IF (p3==2) THEN (3) ELSE (0))
p5=IF (p3==1) THEN (9) ELSE ( IF (p3==2) THEN (12) ELSE (0))
And starting with NX 8.0 you now have another and perhaps more elegant option and that is the new 'nth' expression, in which your set of expressions would look like:
p3=1
p4=nth(p3,{7,3})
p5=nth(p3,{9,12})
In either case, changing p3 from '1' to '2' would change p4 from '7' to '3' and p5 from '9' to '12'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
